Aluminum Radiator corrosion?
Old Mar 4, 2006 | 09:56 PM
mjshort's Avatar
Car: 82 Z28
Axle/Gears: Stock
I read somewhere that if you use an aluminum radiator with an iron block, it will cause the radiator to corrode more quickly. I'd like to use aluminum due to weight and supposedly better cooling, but I don't want to have to replace it sooner than a brass radiator. I see Summit has a direct fit for $244.88. Not bad.
My question is does anyone know if this is true? Has anyone had an aluminum rad. with an iron block for an extended time, without problems?
Old Mar 5, 2006 | 01:31 AM
FreeLoader's Avatar
Car: 1997 Camaro z28
Engine: 350 LT1 built to LT4
Transmission: a
Axle/Gears: 3.23 posi
I've personally never heard that, but if I remember correctly all the 4th gen camaros used aluminum radiators, and all the v-6's and lt1's were cast iron blocks.
also, autozone sells a direct-fit aluminum radiator as well as a 3-core copper for about 120 bucks each.
the 3-core will cool your car much better, but I personally went with the aluminum because it'll still cool better than stock(although not much), and it's a few pounds lighter.
I've only had my aluminum radiator for about a month though, so I couldn't tell you about long term corrosion.
Old Mar 5, 2006 | 10:58 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
A CHILLING STORY
<CENTER><B>
Not a problem. In fact better equipped
RS thirdgens came with aluminum’s.
No corrosion with mine.
</B>
<P>
<TABLE BORDER=9 CELLPADDING=18
<TD BGCOLOR=black WIDTH=60><B><H3><CENTER>REFUSE
.TO
.LOSE</TABLE></CENTER>
Fanatic1074
Oct 3, 2022 05:57 AM
jrdturbo
Mar 31, 2016 02:58 PM
school boy
Oct 22, 2015 11:47 AM
bigjay89gta
Oct 15, 2015 08:04 AM
lanceflame44
Sep 25, 2015 12:28 PM
