2.8 overheats when heat is off
Old Mar 26, 2006 | 05:08 PM
sccasey's Avatar
Have an 87 Fbird that overheats only when the interior heat is off. Is this a sign the thermostat is bad? Btw, warmed up the car with the heat on yesterday and both upper and lower hoses got very warm (upper one first) and fan kicked on when coolant in expansion tank reached "hot" level. Any help appreciated.
Old Mar 26, 2006 | 07:40 PM
89stroker's Avatar
Car: 89 K2500
Engine: 383 tbi
Transmission: built 700r4
Axle/Gears: 4.10 14 bolt
what does your temp gauge show? if it gets up near the max, i'd definately check your thermostat, stat.
sheachopper
Jul 31, 2019 11:27 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
