cannot remove overflow tank
Old Mar 27, 2006 | 08:47 PM
tomwilson's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: Th-700r4
I cant get the nut off the stud instead the stud with the nut on it spins. Is there a way to stop the stud so I can take off the nut?
Old Mar 27, 2006 | 10:06 PM
CamaroKid89RS's Avatar
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
I had the same problem with mine, although I never found a solution. I just left the stupid tank.
Old Mar 27, 2006 | 10:25 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
vice grips ?
Old Mar 28, 2006 | 12:24 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Have you checked to see if you can gain access from the back side of the stud to get a wrench on it?
Old Mar 29, 2006 | 12:05 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
I have the same problem, Im just going to cut that stud off cause im going to get a new on in there with the LS1.
Old Mar 30, 2006 | 07:58 PM
MdFormula350's Avatar
ur not the only guys lol
I spent 5 minutes thinking i was lossening that nut / bolt in the fender well, then i was like wtf. i took two pry bars and ripped that coolant tank off!!!! man that thing is on there!! lol
I put on the older smaller coolant tank and it fits great and bolts on alot easier!!
1992 Trans Am
May 10, 2023 07:19 PM
Strick1
Aug 27, 2015 08:57 PM
Glowsock
Aug 26, 2015 12:28 AM
theurge
Aug 21, 2015 12:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
