Upper Rad Hose for 1.5" neck and Northern Radiator
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
I've got an '87 IROC with a 1.5" aftermarket water neck and a Northern Aluminum radiator. The stock upper radiator hose is 1.25" ID and will not fit the water neck or the radiator outlet. Does anyone have a part number for the 1.5" ID upper hose with the correct shape?
Thanks. -Neil
Thanks. -Neil
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
Originally Posted by Forshock 85TA
1976 corvette
i believe that was the year. Wont with drivers side AC
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
not sure, i wasnt asked that. I just went to the parts store and asked for the part, and it worked no problems
On the lower hose there is no "fitted" part, lots of "lube" and some work.
Pac J
May 17, 2020 10:44 AM
