Second Fan DOESNT COME ON
Old Apr 20, 2006 | 10:24 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Alright, my second fan will not come on, even when the temp reaches 240-250 Even when the AC is on, the second fan does not spin.
What's causing it to not come on?
Bad Relay?
Bad wiring?
Old Apr 22, 2006 | 01:22 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Someone knows something i know it.
Old Apr 22, 2006 | 01:42 PM
nameinuse's Avatar
Does the fan in question work if you feed it 12v directly?
Old Apr 22, 2006 | 08:20 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
sorry for a dumb question, but, how do I feed it the 12v directly?
Also, the guy who owned the car before me, wired the driver side fan to stay on all the time I think
Old Apr 22, 2006 | 09:17 PM
tchome1956's Avatar
second fan...
I could be the electrical connector to the fan. as thirdgen's age that becomes a bigger issue.
Old Apr 22, 2006 | 11:24 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
It could be a bad fan switch in the passenger side head. But it should still go on with the AC. Neither on mine worked (Temp or AC), but the fans did work when supplied with 12v. I replaced relays..etc It ended up being a broken wire.
Old Apr 23, 2006 | 09:12 PM
VA1991Z28's Avatar
Car: 1991 Z28
Transmission: 5-spd
I had the same issue with my Z28. To feed it 12V directly, unplug the connector that goes to the fan, get some "testing leads, wires with the alligator clips on the ends" from RadioShack or wherever. Now check your wiring diagram, and connect the clips to the fan connector leads and then ground one to the frame and touch your battery + terminal with the other. The fan should spin. Make sure you don't reverse the wires. Other causes for aux, fan not coming on: Relay, bad fan switch between #6 & #8 spark plugs, the connector that connects to the fan switch corroded. You can check the fan switch, by uses the test leads and grounding the fan switch connector and turn the key to on. The fan should spin.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
