AC Not Turning On The 2nd Cooling Fan
Old Apr 23, 2006 | 09:13 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Alright, when the car is running, the driver side cooling fan stays on all the time, I think the guy who owned the car before me wired it that way, but my problem is, the car sometimes shows it's running at 245-250 degrees, when it did this, I pulled over and the second fan wasnt running, so, I turned on the AC, the passenger side fan STILL didnt come on.
I started messing around with car on, I pulled the relay, the fan shut off, I plugged it back in, it worked, so, the relay isnt bad, I unplugged a connector, same thing.
I noticed that my overflow tank wasnt even 3/4 full when it read 245, so i think it might be a bad temp sensor maybe?
Isnt turning on the AC supposed to turn on BOTH of the cooling fans?
Old Apr 24, 2006 | 01:40 AM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
had that happen with my car once and it turned out to be a fuseable link in one of the wires, dont remeber witch wire, but easy to check with an ohm meter
RazorN8
Jan 7, 2022 11:44 AM
Papaginos
Sep 27, 2015 03:29 PM
Ducati900ss
Sep 2, 2015 09:05 AM
TheExaminer
Aug 19, 2015 10:07 PM
Leggman1
Aug 6, 2015 04:15 AM
