LO3 Overheating Again...
Old Apr 27, 2006 | 08:29 PM
Bacon88's Avatar
Car: 1988 Camaro
Engine: LO3
Transmission: A4
Okay so now when I am driving in stop and go traffic I overheat. My fan is not working so that is the reason why, but I dont know why my fan is not working. Also my temperature gauge is broken. Im not sure, but are both of the units that control the gauge and the fan on the same wire? And I was talking to a guy at Shucks and he said that if I touch to wires together or something, the fan will stay on as long as the engine is on. I dont know what to do...Any help is greatly appreciated, Thanks.
Old Apr 28, 2006 | 12:31 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Theres two seperate senders. The one that contorls the fan is on the passenger side fan. Make sure it is switching from an open circuit to a closed circuit when your car gets hot.
Old Apr 28, 2006 | 07:44 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
1) With key on, turn your A/C controls to Max and see if fan works. On a single fan car, the fan will come on with A/C on, on a dual fan car, one of the two fans will come on. This will let you know if the fan actually works and is getting juice from battery. If nothing, then you have a bad wire to the fan or a bad fan motor - they are like $30 for a new fan.
2) Check the relay - located on the driver side firewall, next to the brake booster - it should be in a metal enclosure - there are 2 of them, one for fuel pump, one for fan - try getting car hot, turning it off, swapping those relays quick, and turning key back on to see if fan runs. These relays are like $5.
3) Fan Switch - located on pass side has a single wire plug to it. There are 2 sensors there with single wires - one is Fan Switch, one is Knock Sensor (I don't remember which is which). Remove the connector (squeeze it), and with key on, ground this wire to the chassis. If the fan comes on, then you need a new Fan Switch. If it doesn't, try the other connector same side same looking connector to make sure you didn't ground the knock sensor instead. If you need this switch, get a good one, skip the autozone junk - go to Carquest or Napa. And wait til car is cool - there's alot of coolant coming out in your face to replace the switch.
Hope that helps.
Old Apr 29, 2006 | 08:16 PM
Bacon88's Avatar
Car: 1988 Camaro
Engine: LO3
Transmission: A4
Thank you for all of the help. I am replacing the temperature sending unit to fix my gauge and then I'll hook up my testing light and see what happens. Again, Thanks all.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
anesthes
Sep 21, 2015 10:24 AM
64Chief
Sep 12, 2015 08:05 AM
J.C. Denton
Sep 8, 2015 05:35 PM
