Water Pump question
Old May 1, 2006 | 08:24 PM
rapidfiremeyer's Avatar
Water Pump question
Do you have to pull the radiator to remove th water pump?? And do I need a high performance water pump or can I just use a standard. I have a 88 Iroc with a 305
Old May 1, 2006 | 08:26 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
no the radiator can stay. i would replace the upper and lower hose along with the thermostat and thermostat gasket while you're there. any old water pump will work, i'd recommend one with a lifetime warranty in case you ever need to replace it in the future. can be bought from a local parts store.
Old May 1, 2006 | 08:47 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
stay with std one on daily driver
Old May 1, 2006 | 10:25 PM
Thanks but my water pump hasn't gone out, the pully is just sloppy and growling and the belt or something is squeeking. Still cools just fine. Still think I should change on the hoses and thermestat???
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
