overheating 87 Z28
Old May 17, 2006 | 07:44 AM
savage7102's Avatar
Car: 2002 camero v6, 1987 Z28
Engine: rebuilt 350
overheating 87 Z28
I have a overheating problem. It has never overheated before i stripped off my a/c. so i bought a new 160 degree thermosta and still overheats. would taking off a/c have anything to do with this. It wasnt hooked up before i took it off
Old May 17, 2006 | 07:46 AM
eric1984z28's Avatar
Car: 1984z28
Engine: soon to have ls1
Transmission: soon to have t56
When does it overheat? sitting in traffic, riding on the highway, all the time? that information will help to diognose the problem.
Old May 17, 2006 | 09:04 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
I agree knowing when it overheats would help.If she overheats on the highway would lead to checking the under car air dam.What type of cooling fan is on her ie;flex,clutch driven,single electric or dual electric?Were you having cooling problems before you removed the A/C(with dual fans the left-passenger-fan control circuit runs thru the A/C high pressure switch).
Old May 17, 2006 | 07:02 PM
savage7102's Avatar
Engine: rebuilt 350
Ok it overheats all the time i start the car and 10 minuts later it is a 220 degrees. I have the electric fan that turns on when the car is started. Like i said it juststarted after i took off the a/c
Old May 19, 2006 | 07:05 AM
savage7102's Avatar
Engine: rebuilt 350
ttt
Old May 19, 2006 | 12:09 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What all did you remove with A/C?
Bubbajones_ya
Jul 6, 2024 08:32 PM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
blackz281le
Jan 11, 2016 07:51 AM
1992Z28!
Nov 19, 2015 07:33 AM
