dual fans ?
Old May 27, 2006 | 10:35 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
dual fans ?
Will the dual fan setup from a 4th gen like say a 96 or 97 camaro or firebird fit directly onto my thirdgen radiator?...92 rs 305 T-5
Old May 28, 2006 | 10:28 PM
dwillis's Avatar
Axle/Gears: 3:08
anyone know?I sure as hell don't
Old May 29, 2006 | 05:01 PM
Redbird's Avatar
Car: '87 Firebird
Engine: '89 Corvette L98, unstock
Axle/Gears: 3.23 posi
Not as a direct "bolt on". The 4thgens use a "hook and tab" mounting system, where the 3rdgens use a "clamshell" type of bolt on assembly.
If you have even a little mechanical/fabrication aptitude you could probably adapt one to fit your application. Try to find a V6 dual fan set up. The dimensions are one inch smaller than your 3rdgens. The LT1 fans are two inches wider and may be harder to fit.
ZEEYAA
Apr 16, 2023 08:29 PM
sheachopper
Jul 31, 2019 11:27 AM
91 SrS
Oct 7, 2015 04:32 PM
Fanatic1074
Oct 2, 2015 03:47 PM
zman1969
Oct 1, 2015 11:09 AM
