Coolant Temp Sensor question...
Old Jun 5, 2006 | 03:46 AM
1BadGTA's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7 Liter
My temp gauge has been reading 'cold' the last couple weeks. I replaced the thermostat, and it's still happening. I ran a scan and came up with no codes. Is this definately the coolant temp sensor? Or could it be something else? Thanks.
Old Jun 8, 2006 | 12:25 AM
jeeps2creep's Avatar
Car: Jeep Scrambler
Transmission: 4L60
Did you check the correct one? The sending unit that gives the gauges there reading is on the drivers side just under the 3/5 exhaust manifold or there close. You cant miss it....let car cool and put you hand down under there and make sure it is connected. IF not replug it in and you'll be good to go.
Old Jun 9, 2006 | 05:35 PM
1BadGTA's Avatar
Engine: 5.7 Liter
Oh I didn't know about that one. What is the sensor called? And why did it not set off the SES light? Thanks
Old Jun 9, 2006 | 08:23 PM
nameinuse's Avatar
You have two temp sensors on your car,the CTS(Coolant Temperature Sensor,sends info to the computer) that sits on the intake right beside the thermostat housing.This one may or may not give a SES light when bad.
The other one,in the drivers side head,is for the gauge and has nothing to do with the computer.
Old Jun 15, 2006 | 07:58 PM
1BadGTA's Avatar
Engine: 5.7 Liter
Do you have a diagram of the location? I can't seem to find it in my manual. Just the coolant temp sensor. Thanks again.
Old Jun 15, 2006 | 10:16 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
The coolant temp sensor (CTS) is for the computer and has yellow and black colored wires. The temp sending unit (TSU) is the one screwed into the head and has a single dark green wire plugged into it.
Old Jun 16, 2006 | 08:13 AM
NEAL12345's Avatar
I HAVE A 1988 GTA TRANS AM ,AND IT KEEP RUNNING HOT .I NEED HELP.NO
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
FormulasOnly
Sep 10, 2015 09:07 PM
