160 degree thermostat
Old Jun 8, 2006 | 05:26 PM
az_brent's Avatar
Car: 1985 firebird s/e
Engine: 388ci stroker
Transmission: stock, t-5?
i have a 1985 firebird se with a regular firebird hood and with a new engine in it that i built. i stuck a 160 degree thermostat in it and ive only had overheating problems due to the lack of ventallation what is everyones take on how well my choice was to use a 160 degree thermostat?
Old Jun 9, 2006 | 06:17 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
did you burp the air out?
i like 160's myself, i prefer the balanced sleeved ones, as they flow more
i also try to drill small holes in them to let the air bleed out easier
also make sure your raditor is clean, fins are good
and you have the lower air dam spoiler
e-fans might help as well, i prefer them in puller setup
i've also had luck using the flow kooler water pumps too
timing and jetting can also cause over heating issues too
plus if you have an auto, try running it to a seperate tranny cooler too.
i've done that in the past with great sucess for cooling the tranny and engine/rad too
Old Jun 9, 2006 | 06:56 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
I run a 160 also, and it works great for me. Everything has to be in good working order for Arizona though....
I also have a Hypertech 177 fan switch, a new radiator with dual Spal fans and I run Water-Wetter. My car
runs right at teh thermostat, 160-170.
Old Jun 9, 2006 | 07:05 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
my 160* runs fine, I'm not a believe in how important burping the system is, as I think it'll do that on it's own, but if you have a problem, it's worth trying.
My car runs nice and cool.
of course make sure your air damn is on, maybe flush your cooling system as well.
Old Jun 9, 2006 | 07:44 PM
az_brent's Avatar
i have the air dam but i have a pully fan and i want to upgrade it but just dont kno what the best is to get. i wouldnt be suprised my timing is off due to im the one who built the motor but other then that the radiator and block should be clean. i had the block hot tanked and ive had teh radiator checked prior to installing it. but thanks for the info guys
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
