Fan pin question
Old Jun 20, 2006 | 11:11 AM
Kevin Vandevenne's Avatar
Car: 87 IROC
Fan pin question
Not sure if this should be here on in the electronics section, but here it goes. I have a stock dual fan setup from a 91 GTA. I do not have the original harness for them. I plan to run both off of seperate switch/relays. On the fans where the GM electrical connections would plug into are, there are 2 pins. Which one is the ground and which is the positive pin?
Old Jun 20, 2006 | 04:14 PM
plndtx's Avatar
Car: '92 Heritage Z28 Convertible
I think you can just pick one for the + and one for the -. If the fan runs backward, switch them.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
