Fan Problem
Old Jun 20, 2006 | 06:18 PM
Cybnext's Avatar
Fan Problem
The fan on my 92 Firebird with a 3.1L v6 won't turn on. I've already replaced the CTS on the intake, also replaced all of the relays on the driver's side firewall. I was wondering though, what is the larger block box with two plugs coming out of it does? Anyways, back to the main problem. I can ground the dk grn/wht wire coming off of the relay and the fan will turn on. So what might be wrong in the circuit that isn't allowing it to kick on when it reaches 220*?
It also won't kick on with the AC because I think the high pressure switch is shot. So I have to attempt to replace that also.
Main questions are in bold
Old Jun 20, 2006 | 06:49 PM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
just wire the fan to a switch. If you dont know how to do that PM me. I did it on my car and it solved a lot of headaches.
Old Jun 21, 2006 | 03:50 AM
Cybnext's Avatar
I thought about it, but I'd like to leave the wiring factory.
Old Jun 21, 2006 | 06:26 PM
Cybnext's Avatar
ttt
krisner89
Oct 10, 2015 06:03 AM
utfan01ss
Sep 28, 2015 12:17 PM
Papaginos
Sep 27, 2015 03:29 PM
JHX
Aug 29, 2015 02:30 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
