Fan works when it wants to very weird
Old Jun 24, 2006 | 01:29 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
i have a '92 rs heritage edition and just recently put a custom bulit 350 in it. Ever since the engine swap the fan turns on and off whenever it wants, sometimes causing my car to run hot. I bought a new fan switch, replaced the relay, and all connections are good. It always comes on when i turn my a/c on, but only sometimes without. Any ideas?
Old Jun 25, 2006 | 03:52 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
Two things to check...when you turn on the ac check power or voltage at the fan connectors itself and see if power is there.If it does then the fan motors are likely going out ...if not get a scanner and check the ac function.The scanner will tell you when the ac switch has been activated,if its not receiving a signal you have some electrical issues.It will also tell you if its low on freon,there is a code for it.Sometimes the fan(s) wont come on till the ECM sees pressure from a ac pressure sensor,might have a wait a few minutes once you turn on the ac.
Old Jun 25, 2006 | 10:14 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
thanks ill be sure to try that soon
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
sreZ28
Aug 14, 2015 07:48 PM
Leggman1
Aug 6, 2015 04:15 AM
