Upper Radiator Hose
Old Jun 24, 2006 | 08:33 PM
newgrounds911's Avatar
Upper Radiator Hose
Hi I have a 1986 Firebird Trans Am and seem to be having cooling trouble, I recently replaced the thermostat with a 160* thermostat and the car no longer over heats, however the upper radiator hose is real stiff. The engine is a 305 carbuerated, any advice or help is greatly appreciated
Old Jun 24, 2006 | 08:52 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I'm not too sure what you're getting at, but maybe you should just replace the hose. It isn't very expensive and only takes a few minutes. And by the way, I think 160* can actually be too cold in some cases. A 180* is usually a safer choice. I could be wrong though.
Old Jun 24, 2006 | 09:09 PM
I have concluded that the radiator cap is bad but would this have anything to do with the upper hose being real stiff while the car is running
Old Jun 25, 2006 | 09:06 AM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
If the hose is hard to squeeze when the motor is up to temperature, that is normal. There should be about 15 pounds of pressure in the system. If the hose is haed to squeeze when the motor is cold, replace it.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
