strange coolant leak
Old Jul 11, 2006 | 08:10 PM
noisyme's Avatar
i have a 1982 trans am 350 5.0. temp reaches 220 and when i shut the engine off, coolant leaks out of the upper hose connected to the radiator neck. replaced the hose twice. still leaks. almost as if clamp wasn't tight enough. there is a half of a lip on the radiator neck, could this be causing the hose clamp to tighten the hose in an irregular manor allowing the leak?
Old Jul 11, 2006 | 08:18 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
had the same problem turned out I sprung a small pin hole leak in the side tank of the radiator.I think your going to have to repair/replace the radiator.
Old Jul 12, 2006 | 03:50 PM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
Sounds like there may be a crack around the neck where the hose connects to the radiator.
Old Sep 26, 2006 | 08:26 AM
Rick James's Avatar
Car: 1986 IROC Z
Engine: 305 4bbl.
I just found a leak right under the hose on the drivers side. It was all good till this AM. Start it up, idel to the mail box round the corner, pull away and see some fluid. go look and its green! look under the car and I have a rapid drip, almost a slow pour from the back drivers side of the radiator. Pop the hood and I see a lil steam from under the top hose and look closer to find a lil bit bubbling from just junder the hose on the "bend" of the radiator wall. I had noticed the resivor looking a lil low, but didnt see any leaks or anything till today.
Is this something that can be fixed? is is worth it to fix? the car has 52,000 OG miles, Im not sure if any of the cooling system has been replaced or worked on in the past. Please let me know what you guys think. Thanks!
Old Sep 26, 2006 | 02:21 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
go buy a stock replacement aluminum radiator, heavy duty if they sell it in aluminum....key word is aluminum, don't take the brass or copper ones as they weigh a ton and do not cool as well as aluminum. I'd also replace the hose clamps since you're not "supposed" to reuse them ever.
Old Sep 26, 2006 | 03:55 PM
Rick James's Avatar
Car: 1986 IROC Z
Engine: 305 4bbl.
^ cool thanks....got a project now!
Old Sep 27, 2006 | 09:44 AM
Rick James's Avatar
Car: 1986 IROC Z
Engine: 305 4bbl.
another question, should the hoses "squeeze" easily? or should they be stiff.
Mine are kinda squishy.
and I have seen radiators from 100-700.....any help on a good one more on the 100 side would be awesome!!!
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
84redta
Sep 19, 2015 09:58 AM
