Coolant leak on 85 Transam
Car: 85 Transam
Engine: 305v8 carburetted
After getting home the other day I noticed a pool of coolant under my 85 transam. Looking into the problem I discovered the leak is apparently coming from under the passenger side ( viewing from front of block ) valve cover & the intake manifold. Any ideas about this please! Intake gasket the cause?
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
Verify its not the fitting for the heater core.
If its not leaking from a fitting/thermostat, intake gaskets
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
I had coolant come down a similar passage. Turns out(after I did the water pump) that it was the thermostat housing. Check around the thermostat for signs of evaporated coolant.
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Drain the coolent out of the system, and then remove the distributor, top radiator hose, heater hose, and then unbolt the intake and see what else gets in your way of taking it off. You should beable to leave the carb on, but if not its not hard to get off and back on.
With the intake off, make sure you have some RTV there and put some around the coolent passeges on the front and the back of the heads, on both sides of the gaskets. Not a lot, just a tiny bead. Also dont forget to put in the gaskets that seal off the lifter vally to the intake on the front and back of the block, or just lay some thick RTV beads and run those up to the coolent passenges.
Hope that helps. There are 100 differnt ways to go about replacing those gaskets, but that way has always worked for me.
