Manual Fan switch...anyone help??
Old Apr 17, 2006 | 10:26 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
On the relay, Green wire with white tracer from what ive read is ground, and the tan one or brown is the power/turn on lead. Can someone explain step by step what needs to be done to be able to wire in a manual fan switch and still retain the factory relay and all of its workings. In other words be able to turn the fan on and off when i want to with a switch, but also be able to have the switch be off and still have the factory settings to be in effect. I just dont want to blow anything on the ecm and all. Thanks guys.
Old Apr 17, 2006 | 10:47 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Switch
What that green/white wire does is...provide ground to the relay.
So....that being said ,,,,all you have to do is use a splice connector on that wire, run it to a switch, run the other side of the switch to ground and when you throw the switch the fan will come on. With it off everything is back to normal.
HTH
Old Apr 25, 2006 | 05:06 PM
ron91rs's Avatar
Car: 91 rs
Engine: 3.1 v6
Ditto, I just did it to mine yesterday and it works fine.I did use a switch with an LED on it so it would illuminate when on...
The install with NO LED is very easy,but a bit trickier with an LED.
The problem is, all the switches i found at the parts stores had the LED tied to ground and switched 12v+.
We need the opposite, 12v+ on the LED and swithing ground (since we are grounding the relay)
All i did was remove the LED, reverse polarity and soldier it back in.
Then find a HOT in Run lead to power the LED..
Old Apr 26, 2006 | 05:48 PM
Formulabruce's Avatar
run a 189 degree fan switch, 180 theromostat.
Old Jun 4, 2006 | 09:18 PM
huntingwood's Avatar
Car: 1989 Trans Am
Engine: l98
Transmission: 700 R4
Axle/Gears: 10 bolt with 3.23s
If you splice into the green/white wire and connect it to ground, it will only turn one fan on, correct? This is what I did and only one fan came on - I think you have to run another switch and ground one of the wires in the other fan relay if you want the other fan to come on too.
Old Jun 7, 2006 | 11:06 AM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
I hooked my switch to a white wire (92 350TPI), and this turns on both fans.
Old Jun 29, 2006 | 08:40 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i just grounded my green wire with the white strip from the fan relay on the drivers side firewall, and the fan didnt turn on??
Old Jul 12, 2006 | 01:28 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
By grounding the green wire with white strip, will the fan run with the key switch off?
I want to be able to run the fan with the key switch off.
Old Jul 19, 2006 | 11:57 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Well, on singe fan setups the green with white stripe wire is the one you have to T to in order to still keep factory settings.
However, on the dual fan set up only the primary fan works the same way. Splicing into green with white stripe wire on the second relay for the second fan will not turn the fan on if grounded.
So, I am kinda searching around to see which wire needs to be T'ed into on the second fan realy to activate the fan.
Old Jul 25, 2006 | 06:12 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
No, fan will only run with ignition on.
You will have to wire up the tan wire straight to constant power source, like the battery, and then run a switch spliced into the green wire to ground.
Yes, it works for both fans, that is how i have mine wired up.
One wire to each green on each relay to a switch for each fan.
junior419
Apr 7, 2025 11:35 AM
gta892000
Aug 11, 2019 11:16 AM
codeysabatini
Nov 10, 2015 04:07 PM
tommy z-28
Oct 6, 2015 10:58 PM
gta892000
Sep 16, 2015 12:37 AM
