overheating with fans on?
Old Jul 21, 2006 | 11:31 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
this just started recently. while driving the temp goes up beyond 190, i turn the fans on (manual overide), and it quells it a little but then after a while it will start to go up even with the fans on and at speed. i recently replaced my upper and lower radiator hoses and drained the entire radiator and replaced with new coolant. it helped out a little but it's still running on the hot side (a hair over 190). it used to go down under 190 no problem. any ideas? i've been having a real wicked misfire going on lately. i had one of my techs scan my car a few months ago and he said i might have blown a head gasket =( are there any tell-tale signs for this?
also, can anyone tell me where i the coolant temp sender, low coolant sensor, and the coolant fan sensors are on my 305 (LB9)? what's the name of the sensor that is in the radiator above the drain **** and the cooler fitting?
Old Jul 23, 2006 | 12:37 AM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Transmission: manual
First off I would make sure the system was burped properly, easy to do. Then if the fans arent cooling it down check and see if you have the original air dams to direct air to the radiator, most people remove them because they scrape on the ground in dips. then i would check the thermostat, cheap part to replace. also want to make sure the rad cap is good, a bad one can cause lots of different problems.
Old Jul 25, 2006 | 06:02 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
ASFAIK, the fans are supposed to turn off at 35mph, this may be due to the air passing through the car goes faster than the fans can flow and thus with the fan(s) on could cause an air restriction.
The coolant temp sensor on your car is on the front of the TPI lower manifold.
there isn't a low coolant sensor on our cars (at least my 5 thirdgens didn't have one).
The Secondary Fan switch is on the pass side head, Primary Fan is controlled by the ECM using the info from the coolant temp sensor on the TPI manifold.
do what hellfire recommends and report back.
Old Aug 12, 2006 | 09:25 PM
GTAman's Avatar
ok, car just died on me 2 weeks ago. i would have posted sooner but i was not close to a computer at the time. see you in the general forum.
Old Aug 12, 2006 | 10:04 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
check your pm
Old Aug 12, 2006 | 10:09 PM
GTAman's Avatar
sent you a PM back
Old Aug 12, 2006 | 10:12 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Sounds like you covered all the cooling issues. However, if your running ruch based on low voltage/spark, you'll run warmer at any speed. Rich or lean that is.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
