fan relay. yes I searched.
Old Jul 28, 2006 | 10:14 AM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
all right, Im going nutso here. I have a 89 RS with 2.8 and SINGLE electric fan. I am trying to wire a switch into my relay so that I can turn on my fan when I want to, but I am getting conflicting info from searching here. I know that I need to splice the green with white strip wire and put it to a switch and then ground, but I am not sure which relay it is. On the firewall by the brake booster there are 3 relays. all with a Green with White stripe wire to them. I also have a relay on my passenger side radiator core support. I have searched and seems that different people say it is either the Relay on the core support I need, or it is the one closest to the brake booster I need. I just want to know which one!
My other option which I really dont want to do is to cut the two wires off teh fan motor and wire 12V straight to the fan through a switched relay. But I really dont want to start hacking like that on my harness. I still want to be able to maintain factory running for the winter.
Could some one PLEASE post a pic with the proper relay circled or something.
Thanks you and sorry for my friggin stoopidity.
Old Jul 28, 2006 | 10:48 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
The relay you're looking for is the one in the left lower corner of this schematic.
You want to tap your switch into the green/white wire on the relay that has the following FOUR wires going into it:
green/white
brown
red (thicker)
black/red (thicker)
Hope this helps!
Lou
Old Jul 29, 2006 | 01:44 PM
Car: 89 RS
Engine: 2.8
got it. Thanks, turns out it was the middle of the three on the firewall.
sheachopper
Jul 31, 2019 11:27 AM
thunder57
Nov 7, 2015 02:28 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
