low pressure sensor or switch?
Old Aug 2, 2006 | 09:37 PM
thirdgen_man718's Avatar
Car: White 1989 Iroc-Z / Teal 91 RS
Engine: V8 350 TPI / V8 305 TBI
ok I got a 2 prong switch, if your looking from the front of the vehicle it is mounted on the left hand side of the accumulator. It has gm and the part numbers 3040500 and 9042 on it. It is a female thread piece that threads onto the accumulator. The threaded piece is cracked and I need to replace it because freon is leaking out. I have did part number and name searches no luck. No part # matches. I believe it is called a low pressure switch or sensor. I am gonna go down to autozone tomorrow and I wanna make sure I get the right thing. Thanks guys. It for a 91 camaro RS 305. R-134a coolant.
Old Aug 2, 2006 | 11:02 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
That is a pressure cycling switch. It cycles the compresser on and off at a specific pressure. It is a pretty standard part and should be availible at any part store. You can unscrew it and take it in with you. There is a shrader valve under it that will keep freon from leaking out after it is unscrewed.
Old Aug 2, 2006 | 11:43 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
that is damn good to know.
Old Aug 5, 2010 | 06:05 PM
mikesanto70's Avatar
Car: 1991 RS L99 1992 Z28 L98 Heritage
Engine: L99 L98
Transmission: 6L80E / 700R4
Axle/Gears: 3.23 LSD disc (both)
Re: low pressure sensor or switch?
can this switch cause freon to leak out slowly
Old Aug 5, 2010 | 09:39 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Wow, this is an old post. It is possible. There is usually an O ring that goes on before the switch to prevent this.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
dcbsracing007
Aug 18, 2015 07:24 AM
jackhammer
Aug 15, 2015 10:04 PM
92camaroJoe
Aug 13, 2015 06:07 AM
