Weird cooling problem.
Old Aug 10, 2006 | 11:08 PM
droppedbagged72's Avatar
Ok I have a 95 LT1 transplanted into a 89 Camaro. The problem I am having is, tonight I drove it around and the temp gauge would not go past 150. That was with the fans off. I brought it home and let it idle in the driveway. The temp got up to 215, fans did not turn on, however coolant started pouring out the overflow. I pulled the fan switch out of the waterpump, and there was plenty of coolant coming out of there. The radiator has a aftermarket cap on it. Any ideas what my problem is?
Old Aug 12, 2006 | 12:09 AM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
simple, your gauge doesnt work.
Verify the actual temp, and why your fan didnt turn on. Check the fan definately.
Old Aug 13, 2006 | 06:17 PM
82 Pace z28's Avatar
Car: 82 Z28 Pace Car Edition restoration
Engine: 5.7l
Transmission: t56
Axle/Gears: 3.23 open drum (not 4 long)
Maybe you had an air pocket in the cooling system, remember that the sender will not read acurately if not submerged in coolant. Bleed cooling system.
Linson
Oct 24, 2025 02:00 PM
Falcon50
Aug 22, 2020 03:26 PM
sheachopper
Jul 31, 2019 11:27 AM
RS Reaper
Oct 17, 2018 07:52 PM
HoosierinWA
Oct 7, 2015 10:15 AM
