A/C Vent ????
Old Aug 13, 2006 | 01:54 PM
Joker1232's Avatar
Car: 92 Z-28 "Z03"
Engine: 5.7L TPI
A/C Vent ????
just fixed my fans in my 92 z-28 350....i recharged the A/C and it blows cold out of the top vents; defroster vents(hopefully will stay that way). But all the vents in the dash do not come on. The AC only works w/ max A/C and with the defrosters. Im not sure why the regular vents in the dash of the car dont blow at all????? any ideas???????? Hopefull this will be an easy fix.
p.s. just noticed that it looks like the unit that controls the heat and a/c may have froze up at some point....looks like there is some residue from melting or heat...could it be the unit itself???
Old Aug 13, 2006 | 03:38 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Common thirdgen problem. Defrost is the default. Vac leak or switch. . Since the subject has been covered countless times, you should be able to find your answer.
JamesC
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
Fanatic1074
Oct 2, 2015 03:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
