A/C equals heat
Old Aug 14, 2006 | 11:25 PM
iroc_cragg's Avatar
A/C equals heat
do most of ur car heat up alot when u use the A/C i dont use mine to often but when i do tha car heats up alot, or could this be a problem with somthing
Old Aug 15, 2006 | 04:43 PM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
Mine does the same thing. I dont like it, but it happens. have you checked the basics? is your fan or fans working, is your coolant fresh, how about your T-stat, it working? is the Air dam in plaece and decent condition?
I made an airdamn, flushed my cooling system completely, wired my fan to a manual switch and now with the AC on it will only get up to 240 going up hills. before the flush and dam I had to cut off the AC or I would be in danger of pegging the temp needle. I still dont like the temps I run at, so I am going to look into a larger core Rad and a better fan.
Old Aug 15, 2006 | 11:03 PM
iroc_cragg's Avatar
yeah ive got my fans wired to the ignition so there always running, new water pump, i gotta take a look at the t-stat tho
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
mfp189
Sep 27, 2015 09:25 AM
