first day i get tags
Old Aug 23, 2006 | 10:02 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
well i took my car out today finally got tags on it and it overheats for a 45 min ride to and from. Never reached the red but just alittle over it. But anyways its got a new water pump, radiator, thermostat, hoses, fan switch, and coolant. stays cool at idle even when its 94 outside and when i get on the highway and drive like 55 its heats up quick whats wrong??? do i have the worse luck my first day driving it
Old Aug 23, 2006 | 11:14 PM
formulafanatic's Avatar
Car: 1989 Firebird Formula
Engine: 305 tbi (not for long!)
Transmission: TH700R4
Axle/Gears: ? 3.08 ?
I wouldn't put all my money on this, but I had the exact situation. Turned out to be a head gasket. unfortunatly, I figured it out to late and the next time I started it just happened to be the time that water had leaked into a cylinder. now i have bigger problems. like I said, it could or couldn't be, but those are the exact symptoms mine showed before it bit the dust. good luck and I hope it turns out to be somthing less complicated than a head gasket.
Old Aug 24, 2006 | 12:18 PM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
Air Dam in place?
Old Aug 24, 2006 | 12:24 PM
admrlam's Avatar
Karma.
Maybe one of those parts you installed, you know.... Doesnt work.
Old Aug 24, 2006 | 01:13 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Originally Posted by admrlam
Karma.
This joke might actually turn out to be the truth.
I had the same problem on another car, perfectly cool at idle, heating up on the highway. New pump, new rad, new everything. Turns out, the pump was a piece of crap, had too much gap between the housing and impeller and was cavitating at higher rpm's, not able to keep up with the load on the highway. A new pump solved the problem right away.
So one (or more) of the parts you installed really could be faulty, what do you know?
Lou
Old Aug 24, 2006 | 02:31 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
i would suspect your airdamn is not in place, or you have a faulty waterpump
Old Aug 25, 2006 | 04:27 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
air damn was messing i got one from the junkyard and now it stays at perfect temperature thanks
RedLeader289
May 28, 2019 01:47 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
