Plastic Radiators w/ Aluminum Core
Old Sep 7, 2006 | 08:15 PM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
Ive seen auto parts and people on this forum use these new PLASTIC/ALUMINUM CORE RADIATORS... are these actually any good? do they last just as long? or are they worse? whats the deal with these? I can get one for my third gen reeeal cheap.... I just want to know how good these are. Thanks
Old Sep 7, 2006 | 08:19 PM
cadman277's Avatar
Car: 95 z28,86 iroc
Engine: 350 lt1,305 tpi
They are real good,the only problem isthat the plastic end tanks seem to start to crack over time,but you can replace those seperatly.Other than that they seem to be a good radiator.They have been using tham on cadillac for a long time,and only the end tanks with cracking pose a problem.
Old Sep 7, 2006 | 10:13 PM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
how long do they go from the point of purchase (assuming you install the radiator and run it from then on) to the point of cracking? a few years?
Old Sep 8, 2006 | 06:46 PM
f1ls1's Avatar
Car: 1999 F-1 Camaro Conv 1990 Iroc-Z
Engine: LS1/L98
Transmission: A4/A4
Axle/Gears: 3.23/3.27
With proper care the radiator should last 10 years or more.
Old Sep 8, 2006 | 08:38 PM
cadman277's Avatar
Car: 95 z28,86 iroc
I would agree,they ussually last betwenn 4-10 years.It just depends on the plastic I suppose.
Old Sep 9, 2006 | 03:47 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
The plastic with aluminum core has been around for 20 years or more and are great. You should not be concerned about the lifespan, mine lasted around 18 years.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
