a/c will not hold a charge
Old Sep 9, 2006 | 08:30 AM
roadking555's Avatar
I have a 1987 GTA 350 and I can't get the A/C to hold a charge. Any ideas where I should start to look?
Old Sep 9, 2006 | 09:04 AM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
Definately a leak somewhere. The most likely place is the compressor seal. Hose connections and connection blocks leak also, but I've found the compressor seal is usually where the leak is and of coarse the most expensive to fix.
Probably going to have to take it to an indy or find someone that has a leak detector. I have one that will detect a very small leak, you can buy a cheap one for about $100. Still less than a lb. of R-12.
If by chance it's one of the hoses, I have a set of hoses off of a '92 Camaro.
Old Sep 9, 2006 | 09:14 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Look for a bottle called snoop (its a soapy liquid). Make sure there is still pressure in the AC system. Squirt the snoop around joints and fittings the most likely place for a leak. You will see bubbles come from the leak.
Old Sep 27, 2006 | 11:17 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
I wouldn't rely on that method.....Only way to find it for sure is to charge the system, inject dye into the system, drive it for a few days then run a UV light over the whole a/c system, that leak will glow. Only really true reliable way.
Old Oct 23, 2006 | 10:06 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
I built chillers for a couple of years and I did the brazing on them. We found 90° of our leaks with snoop. The really small and hard to find leaks were detected by filling system with Helium and using an Electronic leak detector. We never used any dye.
Falcon50
Aug 22, 2020 03:26 PM
apie2546
Oct 16, 2016 02:24 PM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
RS Reaper
Sep 27, 2015 07:04 PM
