need ideas on overheating
Old Nov 3, 2006 | 01:57 PM
edman87k5's Avatar
Car: depends on the weather
Engine: several
Transmission: all manual
Axle/Gears: lots
My 91 rs is running on the warm side.
I know the cooling fan was cycling properly a few days ago because it was idling at my buddy's shop and you could hear it going on and off.
2 days ago, I was stuck behind a backhoe on the highway for 5-6 miles at about 15-20 mph. Heat kept going up, cooling fan never came on, got to around 240 before I could get going and get some air through the radiator to cool it back down. Came home, parked it in the shop and let it idle, cooling fan never came on. It would come on with the a/c on, but not by itself.
Put it on ramps and pulled the coolant fan switch wire and grounded it, fan comes on fine that way. Plugged it back in- no go.
Replaced the switch today with the better 1 that napa sells, supposed to cycle in below 220, I think 208- can't remember.
Still have the same issue, no change.
I cannot reach ma voltmeter to the switch with it installed, but the switch body seems to be grounded.
Did I get a bad switch? That is the only thing I can figure.
How would I test these type switches, put it in an oven and check with voltmeter?
I don't want to go ghetto and make fan run when engine is running, but don't want blown heads either.
Any help is appreciated.
Old Nov 4, 2006 | 06:07 AM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
you can just go back to napa and switch the switch im a having the same problem sounds ghetto but you can pull the hvac/ fan fuse out and turn you a/c to the on position you radiator fan will turn on but not you a/c till you get it figured out and dont have to worry about blowin you heads
Old Nov 4, 2006 | 08:06 PM
edman87k5's Avatar
Engine: several
Axle/Gears: lots
Ok, so my switch is not bad, new one is good, and so is the old one. I tested the old one last night. Did some temp testing today with an IR thermo and found my guage to be way off. It reads 25-30 degrees warmer than the actual temp, so I let car idle longer and sure enough, fan cycles on and off as it is supposed to. I am changing the cluster in the next week or so due to a failing spedo and failed odo, so I will get the guage reading correct then.
Old Nov 11, 2006 | 02:01 PM
EndlessSummer85's Avatar
Car: 1982, 2000 Trans Am
Engine: 350 bored .040 over: LS1
Transmission: Borg Warner Super T-10: Tremec T-56
Axle/Gears: 4.10s; 3.42's
Buy a manual fan switch
Old Nov 11, 2006 | 08:21 PM
CrAzYcUsToM's Avatar
Car: 1991 Camaro RS
Engine: 5.0
Just my 2cents
Your fan motor might need replacing. It might not be making the proper revolutions...
Ususally motor replacement takes 10min and cost about $32......
Old Nov 11, 2006 | 09:59 PM
edman87k5's Avatar
Engine: several
Axle/Gears: lots
Thanks for the ideas, but read my previous post, got it figured out already.
Old Nov 12, 2006 | 05:19 PM
Car: 1991 Camaro RS
Engine: 5.0
Oops i guess I didn't read that last post....lol
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
