Removing the sqaure vacumn device
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Ok guys, I would do a search, if I knew what I want to search for..Help...On my 89 305 TBI, there is a square box on the passenger side, that has heater hoses hooked up to it...I want to get it out of the way...I read a post awhile back ago on how to remove this so the heater still works...Can someone please explain to me what this unit is for...Thank you, Tom
Car: 89 RS, 92 Z28
Jade Grey, Thanks, Ok, I guess, I was confused on the two, the heater valve is what I would like to get out of the way...Is there a way to just have the heater hooked up, as 2 lines...I notice one of the lines on the heater valve run to a point other than the heater core...Anyone got a pic of the hose routing with out this valve...Thanks...
