coolant fan
Old Nov 13, 2006 | 09:23 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
coolant fan
just converted an 84 T/A to fuel injection. everything worked fine except for one thing. My coolant fan turns on when the engine starts and runs continuously. any suggestions
thx
jeff
Old Dec 9, 2006 | 02:01 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Sounds like somehow between conversions the fan is shorted to a hot wire so it stays once you turn the ignition. I have that problem but mine was caused by the previous owner. The fan is controlled by the ECM(car computer). And part of the circuit is the fan the fan relay and the coolent sensor. The coolent sensor tell the computer the coolent temperature and then once it gets hot enough teh computer knows when to turn on the fan. It sends a signal to the fan relay and the fan goes on. If you short out or bypass the fan relay you will get what we have now. A constant fan that is always on. I have yet been able to track down where my fan is bypassing the relay but double check your wiring. The dealership can give you the number code that is printed on the relay so you know which relay to check.
Let me know if this has helped.
Goodluck!
And sounds awesome what your doing. I did the opposite. I have a 1986 TA. I am removing the bumpers and ground effects and replacing with 82-84 parts to look like a 82-84 TA on the outside but will have the TPI engine under the hood.
Old Dec 9, 2006 | 05:49 AM
jjlabinski's Avatar
Engine: shinny 350
It was the cooling fan relay. toast! $11.00 at local federated store.
jeff
sheachopper
Jul 31, 2019 11:27 AM
Fanatic1074
Oct 2, 2015 03:47 PM
