Dual Fan Problems????
Old Nov 18, 2006 | 02:46 PM
cpullma2's Avatar
Car: 1987 Iroc Z28
Engine: 350 HSR
Axle/Gears: 3.27 Borg Warner 9bolt
Ok Here i go I have an 87 Iroc with stock Dual fans. My AUX fan never worked and I am going to run a switch for that 1 by grounding the green with white srtipe wire before the relay.Already checked by grounding wire and it works. The main fain recently stopped working. I changed the coolant temp sensor and the gauge sending unit still does not work. When i jump the terminals in the ALDL it will turn on then. My question is whether it is the relay or the wiring. I know I should try the relay, but I have been working crazy and have been a little lazy at home lately. Just would like to know so when I get some time I can just tackle it and get it done with
Thanks for any input in advance
Old Nov 18, 2006 | 03:48 PM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
Turn on the A/C, this should turn the fans on, if not, check the relay.
Old Nov 18, 2006 | 03:58 PM
cpullma2's Avatar
Car: 1987 Iroc Z28
Engine: 350 HSR
Yea i forgot to tell u that i checked the ac thing and they still didnt work
customblackbird
Aug 15, 2021 10:16 PM
onefreakz
May 14, 2018 12:15 PM
Scamo-2.8
Dec 5, 2015 09:16 PM
krisner89
Oct 10, 2015 06:03 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
