Im going to install a new water pump and radiator...
Old Nov 24, 2006 | 02:49 AM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
I have this reverse rotating water pump BOSCH That I got for my Camaro and im going to buy a new RADIATOR, because my current one is leaking real bad even after I sealed it. I want to know after removing the water pump, and during the installation of the new water pump, how hard do I tighten the bolts? hand tight? or snug tight or what?
I don't wanna rip the gaskest or cause them to leak. This will be my first time changing the water pump, any help and comments are much appreciated
Old Nov 24, 2006 | 08:43 PM
blazed's Avatar
Car: 1986 IROC-Z
Engine: 5.0L 305ci
Transmission: 700r4, shift kit
You want them tight I mean you dont have to have a torque wrench or anything but you want them tight you will not rip the gaskets unless you are doing something really wrong. Also use some gasket sealant one the gasket but not a lot just kinda coat it (HIGH TEMP). But back to the question 3/8 ratchet kinda tight
Old Nov 30, 2006 | 01:16 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
done and done!
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
