coolant gauge not working
Old Dec 27, 2006 | 09:20 AM
dp149's Avatar
Hi,
1983 LG4 4 barrel trans am. The coolant gauge isnt working. Never budges from 100. The heater works great, doesnt overheat so I am guessing the thermostat is fine. I see (2) units. One on the thermostat housing and one on the end of the hose going into the water pump with wires. which one is the coolant sending unit? How can I test it to see if it is bad?
Thanks...I have a haynes book but it shows the v6 engine and doesnt really talk about the v8. Really want the guage to work in case I start overheating.
Old Dec 27, 2006 | 09:23 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
One wire sensor on driver's side cylinder head controls the dash temp guage. Look for a singe wire with spade type connector. It probably just came loose.
Old Dec 27, 2006 | 03:27 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
as naf said, it is on the driver side head. between the 1 and 3 spark plugs. mine likes to fall off also.
Old Dec 28, 2006 | 10:17 AM
dp149's Avatar
Hey Everyone,
No wire or sensor in the location you stated. My buddy has an 85 camaro (he has a special 82-87 firebird.camaro book) and it states that the sensor which controls the gauge is ontop of the thermostat housing (has a femail end on the top of the connector). Can anyone confirm truly if this is the sensor?
I know some sensor is bad because everything cooling wise works (i.e. good heat, not overheating, etc.) just the gauge sticks at 100. I disconnected the sensor wire and my check engine light went on so I know the wiring is good.
Old Dec 28, 2006 | 11:21 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
the sensor in the t stat housing is for the computer, the sensor in the cylinder head is for the gauge.
Old Dec 28, 2006 | 12:25 PM
naf's Avatar
naf
Afraid the book's wrong. There are up to three temp sensors on your engine depending on year/model. The sensor in the water neck provides temp reading only to the ecm. The driver's side sensor connects only to the guage. Most models (except some pre-86) have a temp sensor/switch in the pass side head for the radiator fan.
Old Jan 26, 2007 | 09:20 AM
XxGeinNothingxX's Avatar
Car: 1991 Camaro RS
Engine: 350 bored .30 over
Axle/Gears: Posi 342
Naf is the man, my sensor hasn't worked since I bought my car a year and a half ago. I always wondered what that thing sticking out the head was. Now I know what it is, put my hound down there, found a lose wire and it hooks right up, gauge works now. Thanks guys.
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
Reddeath210
Oct 6, 2015 08:20 AM
TheExaminer
Aug 26, 2015 04:59 PM
fonzie85
Aug 13, 2015 11:50 AM
