Air Conditioning
Old Jan 1, 2007 | 11:34 AM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
Air Conditioning
Hello,
Would there be any concerns with taking the Air conditioning system out of a 1992 camaro 3.1. Reason im doing this is because when i got the car the a/c compressor had no belt on it and it was locked up. Plus its alot of weight just sitting there. thanks
Old Jan 2, 2007 | 08:37 PM
High Toned SOB's Avatar
Car: 85 T/A
Engine: BBC
Transmission: glide w/brake
No problems taking the compressor and condensor out. You;ll need a shorter belt or a idler pulley in it's place. Unless you want to pull the dash out you won't be taking the evaporator out though. A/C doesn't weigh that much, probably 35-40lbs for the entire system. Put a new compressor on it and enjoy it in the summer. It's gonna take more than dropping 25lbs to get that 3.1 into a screamer. Fahgetaboutit
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
jackhammer
Aug 15, 2015 10:04 PM
