305 TPI connection diagram for heater diverter valve
Old Jan 6, 2007 | 08:25 AM
cpgilles's Avatar
Car: 1986 IROC
I have an 86 Camaro IROC TPI that was bought used. I didn't realize it at the time but the heater diverter valve had been removed. I am not sure how important this valve is but I thought I would buy a used one and install it. Does anyone have a connection diagram for the valve? Which valve connection goes to what? What does the vacuum line connect to?
Old Jan 7, 2007 | 09:59 PM
5.7iroc-02ws6's Avatar
Car: 1988 IROC/02 WS6
Engine: zz3 crate w/12 psi ATI and stock ls1
Transmission: 700r4 w/2800 stall and m6
Axle/Gears: 3:42 10 bolt-both cars
vacuum line should connect to the valve if I remember right.. mine always leak after about a year or two... The top heater line out of the heater core goes to the top of the valve, bottom to the bottom and the front comes off the radiator on the psngr side..
Old Jan 8, 2007 | 06:18 PM
cpgilles's Avatar
Car: 1986 IROC
Thanks for the feedback. Were does the vacuum tube go on the other end? I understand it connects to the diverter valve but what controls the diverter valve. It must go to something under the dash and sense when heat is called for.
Old Jan 8, 2007 | 06:23 PM
It connects to the red/blue temp selector... Your hvac system is vacuum operated...
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
