Tstat help
Old Jan 15, 2007 | 07:10 PM
steeljab's Avatar
Car: 87' Camaro
Engine: 305 carbed
Tstat help
Just got a 87 Camaro, could somone send/post a link to a good 180* tstat please? the car runs redline(and more if i'm not careful) air dam is intact, radiator doesn't leak, i flushed it out and put 1/4 antifreeze 3/4 distilled water and a bottle of water wetter in it. i've played with ac/heat and such and nothing there helps. going about 60-65mph cools fine if I don't touch the gas.. I took the radiator out and there were no debris between it and the condensor(sp?). I believe my tstat is the problem because every once in the while it'll decide to cool down and it drops like a rock, so I think the radiator cools fine.
Old Jan 15, 2007 | 11:09 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
you can get a 180 thermo about anywhere. I use stant, I always have, I always will. you can pick them up at Advance. Pn# is 13008.
tommy z-28
Oct 6, 2015 10:58 PM
86IROC112
Sep 11, 2015 04:04 PM
25thannivZ28
Alternative Port EFI Intakes
Dec 31, 2006 11:43 AM
Rhydon
May 28, 2005 11:21 AM
nikh23
Aug 6, 2003 09:46 PM
