Clutch fan replacement
Old Nov 5, 2006 | 04:18 PM
BigDave's Avatar
Car: 92 Caprice Classic
Hey,
I have a clutch fan now is there anything else I could use, I have A/C and my car is on my SIG. Plastic flex or metal, Remove fan totally and put electric fans. I want performance without running hot??
Thanks Dave.
Old Nov 5, 2006 | 05:03 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Welcome to TGO, BigDave. This site is for 82-92 Camaros and Firebirds, but you might find an answer with a search.
JamesC
Old Jan 16, 2007 | 12:45 AM
Guest
Guest
Posts: n/a
Hi,
I have a 1984 Trans Am with clutch fan.
My questions:
1.
Could anybody please explain me shortly how it works?
There is a fluid or what in it...
2.
Can I do any preventive maintenance?
Does it make sense?
Is it possible or the whole thing is totally closed?
3.
Can I replace it with a new fan if it breaks?
Is there any company which has such new fans?
Thank you,
Laszlo
Old Jan 16, 2007 | 10:48 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The fan hub has a viscous silicone fluid in it, and a thermostatic valve. It's a sealed unit so there isn't really any maintenance that can be done. There are a number of sources for aftermarket and replacement fans and hubs.
Old Jan 16, 2007 | 12:09 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
flex-a-lite fans are pretty good.. just replace the clutch part with a spacer, probably 1" or 2", and get a fan that is the same size or bigger than stock.. but for the most performance gain, go electric..
Old Jan 16, 2007 | 12:40 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A clutch fan is actually more efficient than a fixed fan.
Hellbillydeluxe
Sep 22, 2015 09:58 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
Bryan F
Aug 18, 2015 02:28 PM
rsrmoore
Aug 7, 2015 08:44 PM
Leggman1
Aug 6, 2015 04:15 AM
