Stainless Hoses, Sizes Needed
Old Jan 20, 2007 | 03:43 PM
L.I.N.Y.92CAMARO's Avatar
Ok im looking to order stainless hose from jegs for my upper/lower rad. hoses and my heater core hoses. But i have no clue the size they are (-03, -06, -012AN) Also i dont know what fitting i need to make this all work?
Can someone please help me out on this it would be great.
Thanks,
Old Jan 20, 2007 | 06:26 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Well first I would warn you against wanting to do SS hoses. They look great at first but once they start getting dirty they look terrible.
Secondly, what it is going to cost you to do actual ss hoses is quite a bit. You'll need to buy several different adapters to go from using hose fitting, to AN fittings, like connecting the rad hoses to the radiator, and the heater hoses to the heater core.
You're best off buying a ss hose cover kit, where you just cover your existing hoses with a ss sleeve and then use fake AN worm clamps. It'll run you $50 or so, compared to somewhere around $300 and up to do actual SS lines.
Old Jan 20, 2007 | 06:39 PM
I have used the fake sleeves before and they dont look good at all.
You can see the black hose under the sleeves.
Old Jan 20, 2007 | 06:59 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
That's true, but trying to do SS lines on a non race car is not going to look good either because of the adapters. You'll have a small section of hose connecting the radiator/heater core to the adapter that the AN fitting goes on.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
knight72
Aug 10, 2015 09:32 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
