Best Coolant to use?
Old Jan 26, 2007 | 11:38 AM
86redIROC's Avatar
Car: 1986 Iroc Z 28
Engine: 383
Transmission: 4L60
What is the best coolant type/brand to use to run as cool as possible?
I don't drive my IROC in the cold so I don't care about the antifreeze side.
Thanks!!!
Old Jan 26, 2007 | 11:45 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
They are all the same. I run Peak or Prestone. You could just run water if you want. But coolant lubricates the seals on your pump. So I stick with the two above.
Old Jan 26, 2007 | 11:55 AM
Gramps's Avatar
Car: 87 Camaro IROC
if you run just water your block will rust and or crack. ethelene glycol (antifreeze) is designed to reduce the freezing level of water and to prevent it from rusting components. if you have a steel block then you need to run the green stuff, it fights cast iron rust. that yellow or orange stuff is designed for aluminum blocks, it prevents oxidation. i agree with nelapse, peak or prestone.
Old Jan 26, 2007 | 12:08 PM
86redIROC's Avatar
Car: 1986 Iroc Z 28
Engine: 383
Transmission: 4L60
I thought there was some performance or "Race" type coolants out there that drop your operating temps by 20+ dergrees.
In Motocross we have some called Engine Ice that runs cooler than regular antifreeze. Just wondered if there was an automotive coolant equivalent.
Old Jan 26, 2007 | 12:51 PM
redlsone's Avatar
I got water wetter and water (live down south)or at the local parts store there is stuff forgot the name that lowers the temp 20 degrees but havent used coolant for some time.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
