92 camaro heater core
Old Jan 26, 2007 | 12:57 PM
redlsone's Avatar
I read all the tricks ans still find it a pain in the butt to get to the heater core. Once I get it b ack from the body shop I might just bypass it. I have the dash apart and the entire bottom have but still cant get to a couple of screws.It was bypassed when I got the car guess I found out why.
Old Jan 26, 2007 | 05:25 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Your dash is taken apart? It's a lotta work but you are so close. I found it easier to pull the passenger seat, and the center console, open everything up so I could get to those hard to access screws, push a few things out of the way... Maybe more than needed but, it gave me unrestricted access so I did it. You might not need or want to.. but, it's a job worth doing once to get heat back into your ride. The biggest hassle was replacing the tight quaters hose on the firewall. You get that far you'll see what I mean.
Dont give up! Good luck!
Old Jan 27, 2007 | 12:01 AM
redlsone's Avatar
yeah like you said im have way there might as well grit my teeth and keep going,but mine it sucks.
Old Jan 27, 2007 | 12:17 PM
sLoW'n'StEaDy's Avatar
are the camaro ones he same as trans ams? i honestly got my done in less than 1 hour. Start to finish and that included vacuuming the antifreeze up from the old one blowing and washing my windsheild to get all the film off of it. I have abrand new heater core still attached to the plastic piece. if its the same you should only have to undo like 4 bolts, slide mine in and put the bolts back on.
i striiped my car COMPLETELY last week, my GF took it out this time in about 20-30 minutes, i really dont understand why everyone thinks they are so hard.
Old Jan 27, 2007 | 12:43 PM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
I have a core I scavenged from a '92 RS if need one.
Make me an offer if interested. It looks like new.
Old Jan 27, 2007 | 02:00 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
do you have the dash pouch? those allow access to the top screws, which is a lot harder in the camaros.
Old Jan 27, 2007 | 03:29 PM
robotic_junky's Avatar
Car: 1991 Firebird
Engine: n/a
Transmission: n/a
Axle/Gears: 3.27, I think
I must be a slow loser because I worked on mine for 5 hours last night and I'm 3/5 of the way done. Plus I have to repair some of the parts I broke in the progress.
Casey Meyers
Mar 2, 2016 10:46 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
Street Lethal
Aug 14, 2015 08:25 PM
