Loss of coolant pressure
Old Feb 1, 2007 | 12:49 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
As the title states, was working on the 91RS last night, trying to figure out the problem with the heater blowing luke-warm air. Checked the coolant level, at least half empty at the radiator. Filled it back up, started the car and let it warm up, took of radiator cap, no hissing, nothing. Put my hand over the hole for the radiator cap, no pressure. Looked down inside and there is plenty of movement of antifreeze, put back on the cap, checked the coolant lines and could feel coolant running through them as I squeezed the lines. New water pump, new radiator cap, new thermostat 180* slight leak at the thermostat housing but nothing obscene (looks like something slowly ate it away). Any thoughts?
Old Feb 2, 2007 | 07:58 PM
1989CamaroLT4's Avatar
Car: 1989 Camaro RS
Engine: LT1 from '96 Corvette
Axle/Gears: 3.42 diff
I think you are losing coolant and you have to find out why.
Get a pressure tester from AutoZone (or other local parts house) and see if you can find the leak. If you saw a leak at the tstat housing that could do it, I mean it would take a while but you have no idea how long it was leaking. you may have fixed it when you put in the new tstat.
Old Feb 2, 2007 | 09:06 PM
Its not just the loss of coolant that bothers me, more like the loss of coolant pressure. If it was getting any pressure to begin with it would have shot out of the thermostat housing a long time ago. There is enough flow to keep the engine cool and it maxes out at 220*F.
Old Feb 3, 2007 | 06:07 AM
JohnZ28's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
Your cooling systen will not build pressure if you have the cap off or if it is open anywhere. There is a tool for testing rad caps if you think it might be bad. Psi rating should be marked on the cap. Usually a symptom of a bad cap is temp. fluctuating.
Being that low on coolant will affect your heat problem.
Run the car with the cap on and put your hand on the inlet and outlet hoses of your heater core and compare the two. If there is a big difference in temp. then chances are your heater core is restricted. If you are losing coolant it may be leaking and you might not see it.
Old Feb 3, 2007 | 12:13 PM
Gramps's Avatar
Car: 87 Camaro IROC
did you fill up your block at the thremostat when you replaced the engine? chances r that the block doesnt have any water in it so the thermostat cant turn on to allow flow. i bet if you take off the thermostat and fill up the block, you wont have a problem any more.
TBRays98
Sep 6, 2015 05:05 PM
SG91camaro
Sep 5, 2015 10:27 PM
middian
Sep 5, 2015 01:42 AM
RyanJB
Sep 2, 2015 01:27 PM
