Overheating and no heat blowing?!
Old Feb 5, 2007 | 10:52 AM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
Ok, this isnt in my camaro, but the people at the s10 board suck so here is my problem.
it got to around -10 last night and I cant believe that this isnt at least partly responsible for the problems. The truck started reluctantly today and I left is idling to warm up for about 15 minutes. When i came back out to the truck, it was running pretty hot and the heat was blowing cold! I figured if I got it on on the road moving that I could bring the temp down but it just got hotter! my over flow bottle boiled over and I pulled over and let it cool down then i drove home. Heater core?
Old Feb 5, 2007 | 11:54 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Sounds like the coolant froze up. Did you happen to check the upper and lower radiator hoses? Were they both warm?
Old Feb 5, 2007 | 01:10 PM
I am pretty sure, you were right. I tried running it again this afternoon after it has warmed up a bit and it ran fine.
Old Feb 5, 2007 | 03:09 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
Best bet is to flush the whole system and make sure you have a solid 50/50 mix, sounds like you had a bit more water than coolant. If it gets cold again, which it will here around Chicago, you will end up with a cracked block.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
mfp189
Sep 27, 2015 09:25 AM
