What exactly causes the thermostat to work?
Car: '88 GTA
Engine: L98 -350TPI
Ok, What exactly causes the thermostat to work? Like how does the thermostat guage read the thermostat since there arent any wires hooked directly up to the thermostat?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The two have nothing to do with each other. The thermostat has a wax pellet in it that expands with heat to open the valve. The gauge reads an electrical signal from the temperature sender in the drivers side head.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
ill add a little more/say it in a different way
the thermostat is completey mechanical
it is spring loaded
thermal expansion and contraction is how it works most all are 165 to 220 degrees F operational
it is spring loaded
Re: What exactly causes the thermostat to work?
Ill have to check the sender unit, my temp guage has also stopped working (it doesnt read a temp. at all). Should I replace the sensor?
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
if it doesn't read at all, probably the wire came off. sending unit is between #1 and #3 plug, single green wire, i believe...
Car: 1989 Camaro RS
Engine: LT1 from '96 Corvette
Axle/Gears: 3.42 diff
The way to test your gauge (assuming it is your '82?) is to turn the key on, and ground the wire to the sender unit. The gauge should peg all the way to the top. If it does, then the gauge is operable and you have a sending unit or wire issue.
Should also check the coolant. The sending unit needs to sit in coolant, and bc the sender is at the top of the engine, low coolant could lead to faulty - or no - readings.
1992 Trans Am
May 10, 2023 07:19 PM
