Fan question
Old Mar 20, 2007 | 10:22 AM
The White Knight's Avatar
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
Fan question
Am I able to install a motor driven fan on my 89 L03 that has elertic fan? What do I need to install this?
Old Mar 20, 2007 | 12:58 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Fan question
yes if you get the shroud assembly off an 82-86 that has it
and the fan
simple.
good luck
Old Mar 20, 2007 | 01:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Fan question
Not quite that simple, his water pump turns the wrong direction. You'd need to find a reverse rotation fan.
Old Mar 20, 2007 | 10:35 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: Fan question
The fan and clutch assembly for a '95 up S-Series("W" code V6 & 4WD)should work for you as they are reverse rotation.They are the same diameter to fit in the stock fan shroud assembly
krisner89
Oct 10, 2015 06:03 AM
Ducati900ss
Sep 2, 2015 09:05 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
