Transmission cooling line suggestion
Old Mar 25, 2007 | 02:19 PM
xbcrguy182x's Avatar
Hi everyone! I was working on my cooling system today and when i unscrewed the lower tranny cooling line, the pipe kinked. It was pretty much rusted. So i decided to cut off the bad part and try to use compression fittings and a small tube to replace the bad part. Unfortunately, after 3 hrs trying to do this, I failed. The line has a curve so when i put on the fitting, it would be angled and not allign to the hole on the radiator. So I was wondering, should i cut off another 3 inches on the line and replace it with aluminum tubing, since i hear they are easier to bend? Or should I cut off the curve and use a elbow compression fitting to continue the line to the radiator? Thanks in advance. oh and btw, wat flows thru these lines anyway, tranny fluid or coolant?
Old Mar 26, 2007 | 09:13 PM
Re: Transmission cooling line suggestion
bump...shall i take a picture of it and post it?
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
sreZ28
Aug 14, 2015 07:48 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
