Engine Temp gauge doesn't work
Old Mar 28, 2007 | 06:08 PM
ChoobinatoR's Avatar
With the key in run the gauge shoots up to max then falls down to 0. So, it would seem power is getting to it at least. I think it's something in the engine bay not hooked up right if at all.
Check it out: there's a wiring harness that looks like it's coming from the dash because there's a ton of wires, then it seperates on the drivers side down to two wires - one purple heading to the oxygen sensor, and a green wire with a connecter. The green wire's connectors plastic housing is fried, and it's loose just hanging around. What's the green wire connect to, and is where can I find the temperature sending unit? Any advice?
Old Mar 28, 2007 | 06:41 PM
baktrak09's Avatar
Car: 86 camaro, 99 cavalier, 85 s10
Transmission: 700
Re: Engine Temp gauge doesn't work
The green wire is the wire for the temp gauge. the sending unit should be in the head.
Old Mar 28, 2007 | 06:59 PM
Seems most logical, unhooked wire, gauge doesn't work, but how is a flat connector supposed to hook up to the sending unit whose connection is like this? I'm pretty sure the green wire was unhooked since I bought the car too. Anyways, here's the pic of the wire and the sending unit....
I apologize for the poor quality, it's taken off of a webcam shooter thing =P
Old Mar 28, 2007 | 07:28 PM
baktrak09's Avatar
Transmission: 700
Mine has a u shape in the plastic along one of the sides and it slides over the end of the unit and snaps into place. It took me a few minutes to figure that out when I was building my s10.
Old Mar 28, 2007 | 07:36 PM
Gotcha! Must be missing that piece, I'll go check out the autoparts store see what I can find. Thanks.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
justin57
Aug 20, 2015 07:05 PM
