coolant temp sensor
Old Apr 4, 2007 | 01:37 PM
mike86transam's Avatar
coolant temp sensor
i have a 86 trans am tpi and i had a check engine come on i checked the code and it said the coolant temp circuit. i replaced the coolant temp sensor. and the same code is still coming up. the engine light does not stay on. when the engine light goes away i notice a fuel smell and only when the engine dissapears. i noticed when changing the coolant temp sensor there was a sensor right next to it that also has something to do with the cooling system. if anyone would could help it would be greatly appreciated
Old Apr 4, 2007 | 01:45 PM
cool84's Avatar
Car: 84 trans am
Transmission: built 700r4
Re: coolant temp sensor
um what other sensor are you talking about? i didn't notice any other sensor screwed into the drivers side head on my car?
Old Apr 4, 2007 | 01:58 PM
my coolant temp sensor is directly under the throttle body and right next to it to the left is another sensor with a 4 wire plug. i had to pull it out to get to the cts. i'm pretty sure it has something to do the the coolant system becuase when i pulled it out antifreeze came out so i'm not if maybe that sensor could throw the code for a coolant temp circuit
Old Apr 4, 2007 | 02:03 PM
cool84's Avatar
Car: 84 trans am
oh ok well when i thought temp sensor i thought of the one thats on the head that works the guage
Old Apr 4, 2007 | 02:08 PM
no this has nothing to do with the gauge. the car doesnt run hot or anything. but whenever it warms up it wants to die at low rpm take off. like i said when the engine light the car runs fine but when the engine light turns off it will the the die down thing and you can smell gas faintly. i replaced the coolant temp sensor but is still throwing the same code. The other sensor that i am talking about looks exaclty like the coolant temp sensor but is quiet a bit bigger. just curios what that is and if that could be the problem
Old Apr 19, 2007 | 09:07 PM
8996chevy's Avatar
Car: 89 IROC
Engine: 355
Transmission: 5 sp., Alum Driveshaft
Axle/Gears: 3.73 Posi
the other sensor you speak of is the cold start injector switch
Old Apr 19, 2007 | 09:23 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Might double check, the coolant sensor (CTS) that the ECM uses is a two wire senson, black and white wires. The white wire sometimes looks yellow. What was the trouble code number?
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
