Fans stuck on
Old Apr 21, 2007 | 12:48 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
Fans stuck on
today i tried starting my car and when it stalled out and i took the key out of the ignition i did a double take to hear my fans still on? i unhooked the battery and it shut offf and when i connected the battery back it didnt they didnt come back on? im thinking its the relay? any ideas?
Old Apr 21, 2007 | 02:16 PM
BadZSS06's Avatar
Car: 2006 SS 2.0 Cobalt\88 383 Camaro
Engine: 383 Afr 195, 850 cfm hp
Transmission: Dynamic Racing 700r4
Axle/Gears: 9in Ford 4.11 Detroit locker
Re: Fans stuck on
thats what it sounds like the next time they get stuck on (my relay was on the pass sideby the heater box, i believe yours should be pass side up front next to the radiator) just give the thing a tap or two and it should click off. I went through two before i got a good one from advanced auto. but that should solve all your problems. good luck
Old Apr 24, 2007 | 10:08 AM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Re: Fans stuck on
Yep its the relay, happened today again and i tapped it with my philips and they turned off. thanks for the location i spent like 10 mins looking for the cooling section in chiltons
sheachopper
Jul 31, 2019 11:27 AM
tmellott89
Oct 14, 2015 02:06 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
