OEM grade water pump suggestions - TPI
Old Apr 21, 2007 | 06:28 PM
G8T8A's Avatar
Car: '88 GTA
Engine: 5.7L
Transmission: 700R-4
OEM grade water pump suggestions - TPI - bolt torque and thread coating ? added
My '88 GTA TPI 350 needs a new water pump. Are there any brands recommended to get or stay away from? I will call NAPA and Advance Auto, but I know they usually have different brands to choose from.
Old Apr 24, 2007 | 08:55 PM
wicked-irocz's Avatar
Re: OEM grade water pump suggestions - TPI
The brand new pumps at Advance are really good. Made by ASC I think
Old Apr 24, 2007 | 09:20 PM
G8T8A's Avatar
Car: '88 GTA
Engine: 5.7L
Great! I've got one of their ASC HDs on order. The description said "reverse flow" I think. Is that right? A friend of mine works there, and he said the Cardone brand pumps come back a lot, so he steered me in the direction of the ASC.
Old Apr 25, 2007 | 08:52 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Yes the 88 and up with the serpentine belt system use a reverse flow design.
Old Apr 27, 2007 | 04:14 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Reverse rotation, technically.
Old Apr 27, 2007 | 08:52 AM
G8T8A's Avatar
Car: '88 GTA
Engine: 5.7L
Thanks for the help. I have two more questions. Looking in my service manual, I see 30 ft-lbs is the spec for the four water pump to block bolts, but I do not see a spec anywhere for the four bolts that hold the pulley onto the pump. Does anyone know what they should be?
I did a search and have read a few differing instructions on coating the bolts. I have read to use the RTV on the bolt threads (pump to block), and I have read to put a little thread locker on the bolt threads. On my own, I was thinking of putting anti-seize on them. In one of the threads I read, it said the bottom two bolts pass through the coolant passage. What is the correct thing to use on the bolts?
Would a little threadlocker be fine for the pulley to pump bolts?
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
